malcolmxtc avatar image
malcolmxtc asked
Buck Boost BMS lithium protection LiFePO4 config
I'm preparing to replace Victron AGM deep cycle batteries with ULTIMATRON UL Smart BMS 12.8V.
I found this post while looking for any config adjustments needed in my Victron Buck Boost device. My question is, shouldn't the Victron BMS lithium protection on number 29 be activated when using LiFePO4 batteries regardless of the brand?
Thank you
BMS
