ccbluesolar avatar image
ccbluesolar asked
Phoenix compact 24/1600 internal relay switching on Eco mode low power state change
Good afternoon
I have a 24/1600 Phoenix compact inverter. I have it set in eco mode running an imersion heater element. When the stat gets up to temp it sends the inverter into low power.
What I am looking to do is switch the relay contacts on the low power state in eco mode so I can switch an external contactor.
Looking through the VE.Configure utility I am not sure this is possible. Can you please confirm if this is possible or would I need to request a firmware change to enable this?
Kind regards Chris
Phoenix Inverter
Phoenix inverter, or inverter charger?
ccbluesolar avatar image ccbluesolar klim8skeptic ♦ commented ·
Victron don't make a 24/1600 compact inverter charger... As stated, " I have a 24/1600 Phoenix compact inverter."
