alex-morrison avatar image
alex-morrison asked
Backup Generator in parallel with solar, DC loads only
I've got a 3.6 kW (DC peak) solar array fed through three parallel MPPT 150/100's to feed a LI battery bank. The system feeds two small DC pumps that need to run continuously. I want to add a small AC 1-phase generator to feed the loads and charge the batteries if the battery voltage gets too low. Is there a Victron product I should use to rectify the generator output, limit current, and control charging? Can this system operate in parallel with the solar/MPPT's or will there be issues with the controllers fighting each other?
MPPT ControllersGeneratordc system
