Good evening!
Today we released v3.00~15 for testing. Highlights are:
- add logging of generator runtime to VRM Portal (actual visualisation might still need work)
- ESS: add support for all EM300 meters
- ESS: add option to scheduled charging to allow discharging the battery (if SOC is below the configured minimum) while in the window; and more.
- EV Charger: various features and fixes
- Add support for Pylontech batteires having 16 cells in series (rather than usual 15 cells). Thank you Brian Finley!
- Force good settings for Hubble batteries (DVCC on, STS off, SVS recommended off)
Protocols
- Lots of improvements concerning RV-C; to be detailed
- Modbus-TCP: fix issue related to inverter/charger state vs āext controlā.
Iāll add more detailes later, previous message is here:
https://community.victronenergy.com/questions/176323/venus-os-v30014-available-for-testing.html
Also Iāll then go through all comments made in version v3.00~14.
All the best! Matthijs
