leopard-junkie avatar image
leopard-junkie asked
Output Amps on IP65 12v/15a in charging mode only .4 Amps
Good day all:- Please advise, when I purchased my Van, it was supplied with the IP65 12v/15 amp Blue smart charger. Also installed is a 12v fridge/freezer and a deep cycle Gel Enertec 674D-RED battery. When this unit is in power supply mode, I only get 0,4 amps out of the unit which is not enough for the 150w fridge to run*(switches on and off) Once I disconnect the 674D-Red Enertec Battery I get upwards of 4.6 amps. In Charging mode, I get .7 amps, but the fridge still does not run. Please advise what could be the problem.
victron communityvictron
Battery is probably dead/dying or has a high internal resistance.
leopard-junkie avatar image leopard-junkie Alexandra ♦ commented ·
Thank you for your input. I replaced the battery with a new one and the system is now working fine.
leopard-junkie answered ·
