stefano31 avatar image
stefano31 asked
Victron 100/15
Hi there , could someone please help ?
my system is victron 100/15
two 395w panels tied together to make 24v each are 9.55a Imp, vmp is 41.40
Voc is 49.50 ,
two 260amp lead solar battery's not agm
5000w pure sin inverter
is this system ok to run , ? Or is the controller too small ?
it has been running for a month in southern spain ok , controller is hot, but you can hold it with you hand ok ,
the fuse to the pannels is 20a and a little hot on a sunny day ,
is this system ok to run ? Or is the controller too small ?
thanks
stefano
victron communityvictron
wkirby avatar image
wkirby answered ·
What is your battery Voltage?
If 12V then you are getting 200W maximum from your panels.
If 24V then you are getting 400W maximum from your panels.
In each case you will not be getting near the 790W that your panels could make.
For 12V battery you would need a 60A charge controller.
For 24V battery you could use a 30A charge controller.
kevgermany avatar image
kevgermany answered ·
Panels are probably over the limit for winter, unless wired in parallel.
