miltonmews avatar image
miltonmews asked
Charging 12 V and 24 V with the same system
Hi all.
I have a real technical challenge. My barge starter motor is 12 V (tapped from the centre of a 24 V battery pack). My domestic battery system is 24 V. Currently using a 24 V alternator and old Victron charger.
NB: The only reason the previous owner made this work is because both battery packs are connected for the 240V inverter and therefore avoided leaving a battery on the starter pack without a load.
I want to let the 12 V starter system remain but not tapped from a 24 V battery pack. I need to separate the two battery packs.
So to my question - - Using the Multiplus II and ARGOFET how can i charge 2 different voltage battery systems ?
Thank you for your help on this.
SG
Multiplus-IIbattery chargingArgo FET Diode
Mark avatar image
Mark answered ·
Victron Orion-TR Smart 24/12 30A non isolated DC-DC Battery Charger with a dedicated 12V starter battery is what you need
miltonmews answered ·
Thanks Mark.
So no need for the argoFET and just use the DC:DC conv/charger?
Cheers
SG
Correct
