DIONYSIOS KOUTSOUVELIS avatar image
Using Pheonix Inverters and Skylla Chargers on a CAN-bus
Good day
In your manual, for Phoenix inverters 3K/5K, you mention that the inverters can be ordered as 120V/60Hz on request. Can we order a 5KVA Phoenix inverter as 120VAC selectable for 50 or 60Hz?
We want to use three of these inverters in a wye configuration 3*115VAC/208VAC.
We want to use an additional three of these inverters in a wye configuration 3*230VAC/400VAC as a second 3 phase output.
What is the peak power for 20 min at 65Celcius, for these inverters?
Do you have any MTBF data, for these inverters?
Can all 3+3 inverters all be connected on the same VE-bus and then converted to VE-can or must each three be connected on a separate VE-bus and each group (of three inverters) converted with a seperate VE-bus to VE-can module.
We also want to connect three Skylla-i (1+1) chargers to VE-can.
Can all the above operate together on a common NMEA 2000 can-bus?
Thank you in advance
Dion
Phoenix InverterVE.Busskylla-i
DIONYSIOS KOUTSOUVELIS answered ·
Hello
Is there any answer for my question above?
Share
