ripnc avatar image
ripnc asked
How to trigger MP2 2x120 relay on loss of shorepower
When we are away and our coach loses shorepower both AC units will try to run off inverter. My plan is to place a NC 12v coil relay in the rear AC line so that the MP2 relay could kill the rear AC and prevent an overload on inverter. Is this doable via the relay assistant? Will it be quick enough to prevent an overload? Thanks for any insight here.
Relay
derrick thomas avatar image
derrick thomas answered ·
You might also consider the ac output 2. This output is only power via shore power and disconnects on loss of shore power. Non essential loads.
ripnc avatar image
ripnc answered ·
Thanks, I considered that, poses some other issues in my application.
