shannon-lowke avatar image
shannon-lowke asked
My cerbo GX is reading higher current than my shunt
Hi team,
I am getting nearly 2 amps and 0.1 Volts difference between my Cerbo reading and the actual (tong test and meter) reading on my Batteries.
I have a 1000A smart shunt connected to cerbo via Ve-direct.
I am testing at my battery BUS for voltage and both the negative coming out of the Shunt and positive at the BUS
I think this is related to the battery consumption being lower than the actual as well.
Any ideas?
SmartShunt
shannon-lowke answered ·
I found the answer.
I had to do a zero current calibration (which says not usually required.
But this has rectified the issue after carrying it out.
