Richard Weir avatar image
Richard Weir asked
Venus GX relay control via two tempreture sensors in an AND logic
I see that you can set two conditions to switch on relay 2 (relay 1 I am using on a SOC switch) but these operate as an OR logic, ie if one condition is satisfied the relay will close. Can this be changed to an AND logic where both conditions have to be satisfied. I am feeling like the two temperature sensors on inputs 1 & 2 are linked to relays 1 & 2 and as I am using relay 1 with the generator start function (on SOC) I think I might have run out of temp inputs? Any help is appreciated .
Venus OSVenus GX - VGX
