philcollins avatar image
philcollins asked
capacitance tank monitor
Been looking forever for a way to monitor my captivate tank sensors with Venus but only thing I have found is restive.
Short of anything thing from Victron when SiMarine adds NMEA2000 to PICO and their tank senders do you think I will be able to interface. NMEA2000 is a standard protocol right?
Venus OSVenus GX - VGX
Hi, yes NMEA2000 is a standard protocol. A complex one (so even if two companies both comply, things might still not work together) but a standard indeed.
Most nmea2000 senders work on our GX devices.
There is a section in the manual explaining the details: https://www.victronenergy.com/live/ccgx:start#connecting_nmea-2000_tank_senders
Speaking of tank senders: this one seemed quite good to me.
We havent tested it yet though:
http://www.bepmarine.com/en/ts1
ben avatar image ben ♦ commented ·
We have tested and can confirm it works fine.
wikel avatar image
wikel answered ·
I've been using these and they plug and play once programmed for tank size, etc...
https://www.amazon.com/gp/product/B004CFXYBG
lshantz avatar image lshantz commented ·
Can these units just stick on the side of the tank, or do they penetrate the plastic container?
charles-riley avatar image
charles-riley answered ·
I'm using the LevelPro Sentinel Remote tank level monitoring device for a long time without any trouble and also the support team is very helpful. You can also measure the level remotely. So you can check this device from Icon Process Controls website: https://iconprocon.com/product/sentinel-remote-tank-monitoring/
