Since the last Victron update I no longer can see or connect my iPhone 4S or iPhone5 to any of my Victron devices.
Is there a fix for this ? Or a method to roll back the device software? Thanks
Which VictronConnect version is running on the iPhone 4S or iPhone5?
Kind regards,
Thiemo van Engelen
Hi thank you for your reply, my iPhone 4s and 5 are running Victronconnect v5.8 .
I have an iPhone SE1 running v5.75 it is working fine . Also my iPhone XR is running v5.77 and an iPhone 13Mini running v5.8 both are working fine too. But I really do want the 4s working that’s what I bought it for . It’s my wireless display. And it stopped when I updated my devices 4 x mppt”s , 2x voltage sensors and now the smartshunt as well .one by one as I updated them they dropped off the 4s radar .
Even my MacBook no longer connects as well . It’s on v5.77 also . What has happened ? Thanks
Hi @Datsports
The problem is that VictronConnect v5.8 is not able to see the devices when Instant Readout is enabled. So either disable Instant Readout on the MPPTs or use a newer VictronConnect, which requires an iPhone 5S or newer.
The MacBook should still be able to connect though.
Kind regards,
Thiemo van Engelen
50 People are following this question.
