billp avatar image
billp asked
VE.Direct non inverting cable current draw
I have a Victron VE.Bus BMS. I would like to connect the charge disconnect port on the BMS to both MPPTs via the VE.Direct connector on each MPPT. What is the current draw of the input side of the non-inverting cable? The BMS charge disconnect port can only source 10ma so is this possible or do I need to put some sort of buffer between the BMS and the two cables in order to supply enough current?
BMSVE.Directsmart mppt
