tobi79 avatar image
tobi79 asked
MISSING Grid code Germany: VDE-AR-N 4105:2018-11 internal NS protection
Hi everybody,
I am trying to setup my Multiplus 12/2000/80-32. I want to set the grid code to "Germany: VDE-AR-N 4105:2018-11 internal NS protection. But this option is missing. Has anyone an idea why this option is missing? Without setting it correctly my MultiPlus won't work correctly, right?
I did not make any changes so far. Here is a screenshot of my VE Configure.
Thanks in advance
Tobias
gridmultipus
Your MultiPlus doesn't have an internal NS protection.
Only the MultiPlus-II range has it, but the required certificates are currently only available for the 24V and 48V model with 3kVA and 5kVA.
tobi79 avatar image tobi79 commented ·
Thank you for the information. I need to select the external NS Protection und install a separate NS Protection?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ tobi79 commented ·
Depends on what kind of system you are planing.
tobi79 avatar image
tobi79 answered ·
I have 3kWp PV with several micro inverters. I want to charge a 12V 300ah battery with the MultiPlus and feed the energy back during night time. I want to control everthing with a raspberry pi and venus os. Is that possible?
Possible yes. To run that system legally in Germany you need to install an external NS protection.
tobi79 avatar image tobi79 Matthias Lange - DE ♦ commented ·
Ok, makes sense. And I need to select the grid code for Germany with external NS?
