graham-plews avatar image
graham-plews asked
Multiplus error 17 .
The stand alone Victron Multi plus 24/3000/70 is installed in a cinibus, the mains power is via a 13 amp extension cable. Batteries, 4 off 12v 100 amp leisure batteries. 2m of 50mm DC cable between battery and Victron. Remote control on 1 meter of RJ45 cable. Dip switches all off except Dip 7 which is on.
After a period of disuse good fully charged batteries were connected and the mains supply to the Victron switched on. Initially the LED display was ‘mains on’, ‘inverter on’ and ‘bulk on’ within a second this changed to ‘inverter flashing’, ‘ bulk flashing’, ‘overload on’, ‘absorb on’ and ‘float on’ and ‘error 17’ showing on the remote.
All connections have been remade, the RJ45 disconnected and all setting checked. The fault persists. This fault is not uncommon on this forum but I have not come across any solutions todate.
error
