I'm curious if my PWM Light bluesolar 12v charge controller is okay to stay connected with an autostart feature on the 32kva genset. Or should I keep the generator off until disconnecting the two solar panels before using the battery to start? Normally this setup is for a battery for camping, but the generator batteries usually are dead before I need the generator and tired of having to jumpstart from a vehicle.
I'm currently using the PWM on H (manual) setting, but if there is a recommendation of a different setting for my setup would appreciate hearing. Thank you
