nick-johnson avatar image
nick-johnson asked
Offgrid vehicle charging
Is anyone aware of a solution for charging an EV from an offgrid solar installatiion (for example, Fronius + Victron)? Ideally I want a solution where the user can select between "eco" and "fast" charging modes; in "eco" mode it should use excess solar once the batteries are fully charged, while respecting the maximum current limit for the solar inverters.
All the existing solutions I'm able to find for 'eco' vehicle charging rely on measuring exported energy to determine what is available for car charging, which is obviously not an option here.
MultiPlus Quattro Inverter ChargerFronius
ben-rudd avatar image
ben-rudd answered ·
This may be of use.
Off Grid Victron / Fronius with EV charging
https://www.evolutionaustralia.com.au/charge-ev-electric-car-tesla-off-grid-at-home
Would also be interested in other ideas
nick-johnson avatar image nick-johnson commented ·
I saw that, but it has some pretty big caveats! I could improvise a solution using a PLC and battery voltage or mains frequency detection to similar effect without the caveat, but I was hoping for a fully-realised solution.
n-dee avatar image
n-dee answered ·
I'm quite a bit surprised because I did assume that the victron charging station is fully able to work offgrid.
Question to all:
does it charge offgrid or no?
https://www.victronenergy.com/accessories/ev-charging-station
lucca371 avatar image
lucca371 answered ·
At this time EV Charging Station can only charge in grid mode with express pv (firmware 1.24).
Victron is currently developing a new firmware version which support offgrid charging.
