rubicon avatar image
rubicon asked
Installing IP65 Smart Shunt
Should you use split lock washers when attaching 4/0 cable lugs to the Smart Shunt? If so, should you use stainless steel? I noticed the new IP65 doesn’t come with lock washers. Nothing is mentioned in the instructions.
SmartShunt
Paul B avatar image
Paul B answered ·
Its your call - spring washers are supplied so that tension is always held on the connections
