fgarcia avatar image
fgarcia asked
BMV-700 unavailable in Color Control GX although appearing in the device list
Hi, I have a system with a Quattro 12/3000/120-2x50, a BMV 700 and a Color Control GX. In the device list, both the Quattro and the BMV appear with the correct readings, however in the system setup, the battery monitor appears as "unavailable monitor, set another" and in the "pages" nothing is detected, see the photos below. Additionally, I have a VE-CAN connection to automatically start a Icontrol Fischer Panda generator and the option “Generator start/stop” is not appearing in the Relay section of the Settings.
Does anyone have a hint on how to overcome this issue?
Thanks a lot.
BMV Battery MonitorCCGX Color Control
Paul B avatar image
Paul B answered ·
What version of Fw is the CCGX on should be fw version 2.23
Also is the BMV 700 also on the Latest FW
I dont think the can bus can be used autostart on a Fp, you use the relay on the CCGX and conect this to the Fp display directly when the Contacts close the Autostart is acrivated on the Fisher Panda
Under the relay selection in settings select as below
