roma avatar image
roma asked
Phoenix 12/375 not working, need help
Hello everyone,
Thanks for helping me.
My Phoenix Inverter worked well for two years, using It occasionally on my 12 volt system. Then it started to stop workings some minutes sometimes after turning on. Red Led light flashing rapidly. Today it has the same problem but I can't even use it more than 2-3 seconds. Stop working right after turning on. Sometimes it let me charge my phone for 2 minutes and then stop with this same red light problem.
Do you have an idea how can I resolve it?
Is it a part to change ?
I use it in my motorhome in Brazil.
Thanks a lot for your help!
Phoenix Inverter
@Roma
What batteries are you using? Try disable dynamic cut off and see if that changes the behaviour.
