davida380 avatar image
davida380 asked
Rs6000 inverter charger with pylotech battery
Hi can any one help wired up rs 6000 inverter to cerbo gx and pylontech 5000c battery.
Updated everything now rs showing disconnected and sometimes disappears from. Cerbo gx.
Pylontech with victron cable to inverter. 500 kbits
rs inverter
wkirby avatar image
wkirby answered ·
From Pylontech to CerboGX BMS-Can port with a BMS type A cable and terminator.
Make sure the correct end of the cable connects to the battery.
Set this port to 500kbps.
From MultiRS to CerboGX VE-Can port with normal network cable (568B wiring) and terminator (your photo shows this terminator not inserted correctly into the VE.Can port)
Set this port to 250kbps.
BMS cables manual with pinouts:
https://www.victronenergy.com/live/battery_compatibility:can-bus_bms-cable
