Andrew avatar image
Andrew asked
Northants installers
I have 2 systems one offgrid 3kw easysolar II GX 48 and a hybrid system which needs changing as i need 32kw of pylontechs charging - this is a growatt 5kw and luxpower hybrid, would prefer it to be offgrid and use the pv - water heating etc rather than waste it at this time of year. Am in Kettering area if anyone would like to quote swapping inverter charger, or even a better hybrid system.
thanks
installationrs inverter
Did you take a look at that map?
https://www.victronenergy.com/where-to-buy
Andrew avatar image Andrew commented ·
@Matthias Lange - DE yes I did. There is an installer about 20mi away, awaiting further communication. Thanks.
dj-dulux avatar image
dj-dulux answered ·
Can certainly see if its something we can help with, Simon @ AV Candy just in Coventry.
@DJ-Dulux thanks, now identified the real problem, it is the amount of batteries with a poorly configured inverter charger which is also not enough for my system and cannot exceed due to the DNO. I am trying to be as much off grid (in terms of energy) but weighing the cost of a generator with the low pv in winter or just keep feed in electric and gas combi but only plug into the inverter when needed with a diverter and CH switch over to a boiler (as dont have one).
Andrew avatar image Andrew Andrew commented ·
@DJ-Dulux Does you company install Victron off grid inverters? This would be a retrofit from previous system so would need to have a switch over mains power consumer unit amongst other things.
thanks
dj-dulux avatar image dj-dulux Andrew commented ·
Yes, actually preffer off grid, far more challanging to get right and sized correctly...
Cheers,
Simon...
