danielmar90 avatar image
danielmar90 asked
Multi rs solar - Warning#59 acin1 relay test fail
Hi everyone.
Yesterday I have turned on my solar installation, and one of the problems showed up.
When inverter is working without grid connection everything is working perfect. No problem's at all. But when I turn on grid supply the warning #59 ACIN1 relay test fault.
Sometimes it's also showing warning #43 ground fault detected.
All this problems are when inverter is connected to the grid. Without grid all working perfect.
I have traced wires checked connections 10 times, polarity is totally fine, all grounding is fine.
Any help would be appreciated.
MultiPlus Quattro Inverter Chargerrs inverter
danielmar90 avatar image danielmar90 lifeingalicia commented ·
It didn't helped. I have done all that was in there. I have found that electricans from meter company that changed my meter, connected L and N to the wrong pins in main switch (L was connected to N from DB and N was connected to L from DB). So I had to switch the ones on the other side same way as they did to have correct polarity. L to L and N to N. But now when I turn on grid power it's tripping RCD that is connected to the grid. Any idea why ?
seb71 avatar image seb71 danielmar90 commented ·
You should always check (not just by wire colour) which is L, which is N and which is PE before connecting to AC In.
Now there is a chance that something got damaged.
jochen-fuerte avatar image
jochen-fuerte answered ·
I have the same Problem.
But from the beginning L was on L and N on N
Ground on ground
It was and is 100% correct.
But i have still this error.
There are some other ideas or news about this??
Many thanks
@Jochen Fuerte
Do you have a good neutral earth bond? Is there any voltage across there?
jochen-fuerte avatar image jochen-fuerte Alexandra ♦ commented ·
All good there as well. Yes
