eyub avatar image
eyub asked
by pass AC input to AC out 1,2 when inverter fails
Hello all I am wondering if there is a setting using the programmable relay or other relays in the inverter that can be helpful to do so :
bypassing the AC input 1 to the loads those are connected to AC out 1 & 2 in case the inverter fails or shutdowns due to some errors.
ac out 2ac
Alexandra avatar image
Alexandra answered ·
@eyub
The only way is an auto transfer switch. Set up to work independent of the system.
