kaijumod avatar image
kaijumod asked
Multiplus 2 5000va to two separate consumer units
Currently running our static lodge off of solar with 4 pylon tech batteries and the multiplus 2, no grid connection. I want to run power my workshop as well as we have plenty of spare capacity. Obviously ac out 2 is only functional under certain conditions, would it be ok to run another 6mm swa from ac out 1 to the consumer unit in the workshop?? Is there another way to do it that would be better/safer/easier
Any help appreciated
fraser
ac out 2ac
Of course you can connect multiple circuits to the MultiPlus but you will still be limited to the power of the MultiPlus.
So you maybe you overload the MultiPlus in certain situations.
kaijumod avatar image kaijumod commented ·
Thanks, just wanted to be sure, we use very little of the available power, thanks for the response :)
