Michael Weimar avatar image
Michael Weimar asked
Login Username and Password for first use of node red after installation of VRM-OS-large
I tried "admin" and my Remote (VRM) Password, but it did not work
Node-REDinstallation
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
The image is called Venus OS Large and the password has nothing to do with the VRM password. The password of Node-RED is linked to the "Remote console" password, which you can set (and disable) via http://venus.local/ Via Settings -> Remote Console:
Michael Weimar avatar image Michael Weimar commented ·
Thank you so much!
I had password for remote access disabled, however, node red is asking for a password...
Now I have set a password and it works!
Problem solved
A, bye the way,
USERNAME = "admin"
That I found in another documentation....:))
I think, Victron should add this to the installation guide. As it requires to have enabled password for remote access, which is needed for the first acess to nodered and the username is "admin"
