I’m trying to understand whether or not the CANvuGX can be used with non-Victron componants such as a Xantrex pass-thru inverter, and solar charge controllers (3 different makes)…I’m not sure if this is feasible, nor whether there‘s enough inputs to achieve this, nor do I know if another component like the CerboGx would also be required??
At present I do have a Victron BMV 12 meter (with victron shunt) and one Victron smart MPPT charge controller - both are Bluetooth …My two other solar controllers are of different makes…
I checked at the Victron product specific sight but have found the information there to be uber scant or minimalist at best…
Thank You,
Bunkysdad
