gootch avatar image
gootch asked
Node Red access via http instead of https
after I upgraded to VenusOs Large 3.00 Node Red seems to have switched to https and port 1881 and is not accessible via http and port 1880 anymore.
Is there a possibility to activate http again?
I know that https is preferred but there are reasons why this is not possible in my system.
Regards Joachim
Venus OSNode-RED
Dirk-Jan Faber avatar image
Dirk-Jan Faber answered ·
It is possible to let the Node-RED instance to also listen on the external interface by creating the following /data/home/nodered/.nodered/settings-user.js file and restarting Node-RED:
module.exports = {
  uiHost: "::"
xsilvergs avatar image
xsilvergs answered ·
@Dirk-Jan Faber
Should that read /data/home/nodered/.node-red ?
I have placed settings-user.js at the above and it works great, thanks for tip.
Dirk-Jan Faber avatar image Dirk-Jan Faber commented ·
You are right. I've adjusted it in my answer. Thanks!
