Silvio Franceschini avatar image
Silvio Franceschini asked
Access to Red Node via ip adress:1880
Hello
I'm very new to Venus OS large, just installed it and try to connect to signal K and Node Red to have a look. Unfortunately I'm not able to connect to the Node Red server at all. Seams there is a mistake I do. May someone can help me out, as I could not find any further infos.
I tried:
- via venus.local:1880
- via IP:1880
but both does not work at all. I'm able to connect to signalK via both methods :3000
I tried with switched on both signalK and Node Red and just one.
I tried on different browsers, all the same "access denied" error.
As it works with SignalK :3000 I'm don't believe it has something to do with browser setting.
Thanks for your help
Venus OSNode-RED
22 comments
Stefanie avatar image Stefanie ♦♦ commented ·
Hi @Silvio Franceschini,
did you reboot after activating node-red?
Anything in /var/log messages?
Is node-red running? Login to the console and type in
ps | grep node-red
Silvio Franceschini avatar image Silvio Franceschini Stefanie ♦♦ commented ·
@Stefanie
Thanks for reply and help
I reboot and change OS back to original and back to large OS, switched on and off Node Red and reboot.
Now I can’t follow you anymore. Not to much into console etc. I know about them on a computer can use it a bit, tried to find something about venus OS commands etc. online but I guess it exceeds my knowledge.
looked trough some of the manuals but I’m probably more on the enduser side as development.
Looks I need to change to "super user" and create a password etc?
Not sure you want to guide me through all of this. but if you can advice which manual may can bring me forward, would be cool. Gracias
Stefanie avatar image Stefanie ♦♦ Silvio Franceschini commented ·
It's not that difficult.
Yes, to get root access you need to set access level to superuse, create a root password and enable sshd.
Here is the guide how to do this: Venus OS Root Access
Once you have access vis the console, follow my questions from the other post to make sure node-red is running.
Hello again
Have setup root pw and enter via terminal console, easy. but now :-)
root@einstein:~# ps | grep node-red
830 root 1604 S supervise node-red
1450 root 1748 S multilog t s25000 n4 /var/log/node-red
5175 root 102m R node /usr/lib/node_modules/node-red/red.js
5388 root 2684 S grep node-red
root@einstein:~#
To enter the var/log directory I fail. Got some lists with terminal commands, tried around with cd.. , cd/ , ls , etc was not working at all :-/
only thing worked was:
root@einstein:~# pwd
/home/root
Also tried again to reach :1880
Thanks -
It's definitely looking different compared to what the output is on my Cerbo GX. And doesn't seem like it has started node-red. Here is how it looks like:
  914 root      1604 S    supervise node-red
 1528 root      222m R    node-red
 1531 root      1616 S    multilog t s25000 n4 /var/log/node-red
22455 root      2684 S    grep node-red
Not sure what went wrong on your installation, but maybe you could try install the new firmware again. It should work basically out of the box.
In Cerbo go to firmware, install from SD/USB (supposed the swu file is on USB), check for firmware on /SD/USB and press to install.
Thanks, well I tried to install the version 10 no success and I installed the version 12 again and also there still the same:
SignalK is running but not so Node Red. I guess I wait for the next version. Even I can't really believe it has something to do with the system.
venus-swu-einstein-20210111143247-v2.70_3-large-10.swu:
952 root 1604 S supervise node-red
1559 root 1616 S multilog t s25000 n4 /var/log/node-red
4025 root 3040 S {node-red} /bin/bash /usr/bin/node-red
4026 root 3040 S {node-red} /bin/bash /usr/bin/node-red
4172 root 2684 S grep node-red
root@einstein:~#
venus-swu-einstein-20210113205511-v2.70_3-large-12.swu
962 root 1604 S supervise node-red
2794 root 1616 S multilog t s25000 n4 /var/log/node-red
3422 root 3040 S {node-red} /bin/bash /usr/bin/node-red
3423 root 3040 S {node-red} /bin/bash /usr/bin/node-red
3431 root 2684 S grep node-red
root@einstein:~#
Please post an image from the Cerbo remote console "Venus OS Large features" settings. Be aware that you need installer access level (root access as explained) to make changes ie. Signalk enable/disable and Node-Red enable/disable.
I'm still not convinced that node-red is running. By default only Signalk is enabled.
More on that here: Venus OS Large image: Signal K and Node-RED
Sorry to waste your time, may I do something really wrong :-/
I tried again, switch off, reboot, switch on again reboot. all the same:
same when using IP :1880
What is the local ip of your Cerbo GX? And what does it say when you click on details?
If it is for example: 192.168.1.60
use this as address in safari: 192.168.1.60:1880 instead of venus.local:1880
:-) I did, back and forth: ip or not does not make a difference with remote console nighter with SignalK
I see. What about your macOS firewall settings, is firewall off?
Firewall was ON, but I now also tried with OFF, no difference.
Would it not also be the same with :3000? What you say from console its not running at all?
Show more comments
Mark avatar image
Mark answered ·
Please confirm exactly which large image FW image you have installed (provide the file name) and what GX device you are using - there was an issue with a recent FW preventing NodeRED access on VenusGX devices, this issue was rectified in the very latest available large image FW.
PS. I have also moved this question into the 'Modification' section.
Silvio Franceschini avatar image Silvio Franceschini commented ·
Thanks for that, also to Stefanie.
Sadly can not post my answer in the comments. nothing happens after press publish ??
I run it on a cerbo GX and use the "venus-swu-einstein-20210113205511-v2.70_3-large-12.swu" which I guess is the latest version.
janvd avatar image
janvd answered ·
I have the same problem accessing Node Red offline. Unfortunaly I have no internet connection on site. I suspect that the software want to acces https://registry... but can't. The device is a Multiplus GX with a nanopi, large image version 16 and later on version 17. I had no problem on my test setup with a raspberry pi 4 device, however this rpi4 has access to the internet.node-red-nanopi.png
