Silvio Franceschini avatar image
Silvio Franceschini asked
MultiPlus don't reduce charge current commanded from BYD
Hola
This system, 3 parallel MultiPlus-II 48/5000 with 2 BYD BBox LV 14kWh and 2x 250/100 MPPTs.
Its recharging during night time via generator control (No ESS or such).
Now the batteries shut down short after fully charge 100% SOC.
It looks the BYD commanded CCL 0A, but MP-II is still charging with 25 Amp.
Battery shut down after a while.
DVCC is active, no shared sensors are active like victron battery compatibility doc recommend.
Any ideas / thoughts?
Thanks a lot. Saludos
MultiPlus Quattro Inverter ChargerBYDDVCC
