Andrew Austin avatar image
Andrew Austin asked
dedicated multiplus 3phase config for steering ?
The current setup is 3x5kw quattro to supply an AC bus and a 3phase AC bus ... this is used for many loads (like washer/dryer/fridge/etc AND steering pumps) ... lets call this the MAIN-INVERTER-GROUP.
I would like the steering pumps (which are 3phase AC) to be setup their own inverter group ... lets call this the STEERING-INVERTER-GROUP, this way the critical steering system is isolated from non critical things. I would also like the the option to flip the power source to the MAIN-INVERTER-GROUP in case one of the inverters in this STEERING-GROUP dies.
Basically some isolation and backup for steering.
Is there any issue/advice on setting up a system like this?
I have a few hand sketches which are not very good, but could add if that would help.
-- Thanks !
3 phasemultiple inverters
