dbx120 avatar image
dbx120 asked
BP100 does not disconnect even when disabled by remote
I am trying to use a BP100 to disconnect a DC/DC charger from the main battery system.
When the DC/DC charger first starts up, it has a large inrush current that trips the Pylontech battery. I want to use the BP100 to leave the DC/DC charger disconnected until the DC/DC charger has booted up and has begun to output 50V. Once the DC/DC is putting out 50V it does not trip the Pylontech.
What is happening is that, even with the remote jumper removed, the BP100 is still connected and the Pylontech trips out. Victron connect says the BP100 is "disabled by remote", but there is still a connection.
It also seems to be taking the voltage reading from the output instead of the input.
I have tried this in normal, relay and lithium modes.
The DC/DC is connected to the IN and the Pylontech is connected to the OUT
battery chargingRelaydc system
