pietro-ceciarini avatar image
pietro-ceciarini asked
MPPT 75/15 charging 2 batteries
i have a mppt 75/15 smart solar charge controller.
can i use it for charging two batteries at the same time or it works only for one?
how should i connect them to do so?
what are pros and cons?
in case i can't i have to buy another mppt and connect it to the battery, but then how can i switch the PV energy for the two mppt controller?
thanks
MPPT ControllersbatterySolar Panel
kevgermany avatar image
kevgermany answered ·
You can charge two batteries at once by connecting in parallel. They effectively become a single battery. Make sure both are fully charged before connecting.
If you need to keep the batteries separate, use an Orion DC:DC charger to charge one battery from the one being charged by the solar panels.
One controller can be connected to multiple panels.
Panels cannot be connected to multiple controllers.
pietro-ceciarini answered ·
hey sorry, i haven't seen your answer.
sorry also because i really didnt understand how to do. probably i didnt explain so well.
i would like to keep them separate because if one gets broken the other one can still work.
what about this?
https://www.victronenergy.it/battery-isolators-and-combiners/cyrix-battery-combiners
can help?
MPPT Product Page
MPPT Error codes
