iromeo avatar image
iromeo asked
Victron Multi RS Solar 48/6000 connect to VRM (CCGX or RPi)
Hi everyone,
Can someone give a bit more clarity on how to bring the Multi RS in VRM?
The manual is... limited in this regards.
I have a CCGX (on my existing quattro installation) and just bought a RaspberryPi on which I installed VenusOS and I also purchased a MK3 adapter.
From what I can tell, only VECan is available on the Multi RS, but when I connect to CCGX it won't show anything. Do i need the little RJ45 end plugs (which didn't came with any device...) ?
What would I need to connect it to RPi?
Thanks
Romeo
Venus OSCCGX Color ControlRaspberry PiMulti RS
georg-cz avatar image
georg-cz answered ·
Hi there,
Did you find the solution please? I have RS6000 also and I would like to connect it to my rpi. I was thinking MK3 cable will did the job, but just now I realized there is no BUS but CAN. There is also VE.Direct will it work?
Thank you, Jiri
