oskaratk avatar image
oskaratk asked
Trigger Relaise immediately on grid (mains) failure
Howdy,
I have a system - multiplus 24/2000, Cerbo GX. Its a UPS system. Grid is on all the time ( unless it fails .. )
I would like to trigger a relais on the Cerbo immediately when grid power fails, use that as signal for load shedding.
I have been trying to use "generator autostart"
So far, I am getting the "grid lost" alarm
"Auto start functionality" on the Cerbo is on - the conditions are all default.
Am I missing something?
Any hints are highly welcome
Thanks and greetings from cold Colorado
Oskar
Generatorgenerator auto startgen start
Jason - UK avatar image
Jason - UK answered ·
@oskaratk I have a assistant set up on my Multiplus via VE Configure to activate the relay in the event of a grid failure. I then have another assistant set up to switch the relay again when grid comes back on line. Hope this helps.
