benna avatar image
benna asked
VE Direct Smart 12/500 Wattage
I am using a 500W (12V) VE Direct Smart Inverter with plug-in Bluetooth capability added.
The Victron Connect Interface does not quantify power used - it only states that usage is "Normal" (Voltage is however provided)
Is it possible to display Amps and/or Watts?
VictronConnect
kevgermany avatar image
kevgermany answered ·
I think you're looking at the display via Bluetooth that has a circular meter with a 0-200% scale. Watts you can estimate from the white dotted line in the 'circle'. There doesn't appear to be an option to show this numerically.
