hominidae avatar image
hominidae asked
Does GX/VRM support submetering/distinction for AC-Loads, i.e. with using multiple EM24 meters
Hi Folks,
I wonder if I can get more detailed information in VRM portal for my AC-Loads in form a "split up".
My setup:
installed System is a 3ph grid-tied ESS (3xMP2-48/5000, CerboGX, Pylontech Batteries and AC-PV)...all loads and PV are on AC-In
ESS-Grid Meter is an EM24 (RS485 - connected to the Cerbo).
So in the GX Display/VRM I can see one "bucket" of all my AC-Loads.
In Reality, I have different tariffs (and metering) for heat-pump and home.
The metering concept from my utility is a cascade, of two meters.
A: Grid and B: Home
So the Power/Energy used for my heatpump is value of meter A minus value of meter B.
Question is: If I were to deploy another EM24 (LAN version, so no conflict with modbus ID of RS485 ESS-Grid meter) at point A (home), can I have a split/distinct view an AC loads, like total (A), heat-pump(A-B) & home(B)??
Energy Meterpower meter
Energy Meter Selection Guide
