MP2's 3h, Series with the Grid. ESS system. Nothing is on this AC Output.
The stock flow page is selected automatically based on the system configuration. Essentially, ESS will show this page. There is no control over what is shown. It is all automatic.
You have more control over the flow page with GuiMods. You can select a simple flow diagram or select an AC-coupled or DC-coupled page which shows more devices at the expense of less information on each tile.
Based on what I see in the screen shot above, the GuiMods Simple overview is probably best.
GuiMods also allows you to combine all AC loads on a single tile (the one upper right). That will also hide the AC Loads tile you point to but NOT for the stock flow overview.
73 People are following this question.
