estherc avatar image
estherc asked
Victron 2,000 kw Inverter EMF Output
Hi – I am getting a van converted and it was suggested to fit a Victron 2,000 kw Inverter so that we can use appliances when we are not connected to a campsite hookup. I am sensitive to EMF’s so have to be careful when using things like mobile phones and WiFi and therefore check the EMF output of any electrical devices that I will be near. Does this inverter generate an EMF output, and if so can you advise whether this is only when it is being used? Thanks.
victron productsvictron communityvictron
Paul B avatar image
Paul B answered ·
I have no EMF information or seen any Info on theses units. however at idle I would think the EMF would by VERY minor in my opinion (again you need to test this), and as the usage or power is increased the EMF may increase. To what level I have no idea.
Sugest you get a EMP meter and test this yourself,
