rotevery avatar image
rotevery asked
Are My Lithium Batteries Being Overcharged?
Here are the Victron solar generation and consumption charts for my solar system from April 22, 2023 to May 5, 2023, starting from state of battery all packs being fully charged (per the local display on each battery pack). I have Quattro, 2 x 100A Smart Solar MPPTs, 2 x 10kwh Felicitysolar battery packs, 1 x 15kwh Wakatek battery pack. All battery packs 48V in parallel. Each battery pack has in-built BMS. To avoid chance of overcharging, absorption voltage is set at 55.5V while float voltage was set at 54V (I've just now reduced float to 53.6V after the period under review). Total 35kwh (nominal) of LFP battery storage capacity. Why is the power stored in batteries by the Victron Smart Solar MPPT's far higher than the power drawn from the batteries (by much more than my battery storage capacity)? Are my batteries being overcharged?
victron productsvictron communityvictron
snoobler avatar image
snoobler answered ·
Broken graphics.
Answer is no. :)
