Wim Schaap avatar image
Wim Schaap asked
Centaur 12/30 voltage output without load
Hi community, I hope you can help me with a basic question about a Virctron Centaur 12/30 battery charger. I have it on my workbench for repair. The reason that i have it is because a friend of mine connected the battery he wrong way. I had to replace a Schottky diode 30CTQ045 and now I want to measure the output voltage without load but the output voltage is less then 1 volt. Does the battery charger have to provide always a 12 Volt output? Or does a battery actually have to be connected to it?
Hope you can help me out?
Thanks in advance for your assistance.
Wim (The Netherlands)
voltagebattery system voltage
