joris avatar image
joris asked
CerboGX recognizing Pylontech but no data
I'm currently installing a system with the Multiplus-II, CerboGX and Pylontech US3000C batteries. Batteries are connected to the BMS-CAN on the CerboGX with the correct VE.CAN type A communication cable. Did this installation before without problems but this time the pylontech shows up in the device overview but without any data. (SOC, voltage etc). Initially after restart the battery shows as connected, after a while it is disconnected. Anyone had this problem before?
Thanks, Joris
Initially connected but without data.
After a few minutes the status changes to not connected.
cerbo gxPylontech
ejrossouw avatar image ejrossouw commented ·
Try the cable in reverse. Do you have a spare you can try?
Alexandra avatar image
Alexandra answered ·
@joris
It largely depends on the Pylontec firmware and if you are using a hub
Also pins 1-3 need to be empty. Check the manual they usually stress that point.
