Hello, so I been looking at the Cerbo GX to be able to monitor my back up systems remotely, I have 2 smart shunts with BT and a charge controller older model (with BT adapter) I like to know if I can use those 3 items with the Cerbo GX at the same time, and would like to remove the BT adapter from the charge controller if is possible, (maybe by replacing with a victron cable) to connect the 3 devices to the Serbo GX. I see different connectors on the Serbo but not sure if I can have 2 or 3 devices connected by BT or if I will need to purchase additional cables to be able to do this. The 2 shunts are in different systems, but the charge controller is in one of the systems with the second smart shunt. Thanks in advance for any assistance with this.
