sputnik avatar image
Bug in SmartSolar MPPT 75/15 ?
I disconnected the SmartSolar from the solarpanel in my sailboat 16 NOV, but in the app it erroneously indicates that it is still producing solar power, please see the enclosed picture.
The MPPT is still connected to the batteries and therefore flashing the blue LED every 3 s. The batteries are connected to an IP 12/15, that is being powered by 230 V.
Is there a bug in the SmartSolar firmware?
Cheers/ Michael (Denmark)
MPPT - Solar Charge Controllerfirmware updatebug report
wkirby avatar image
wkirby answered ·
As long as the MPPT controller is connected to the battery, it is gong to consume a small amount of energy to run the microcontroller, LEDs, Bluetooth etc. It is not very much, probably less than 1 Watt, which would amount to a few Wh per day. This amount of energy, although in reverse, is quite accurately displayed on your historical graphs. In normal operation with a solar panel connected, these minuscule measurements will be obliterated actual production.
Is there any reason to disconnect the solar panel? If so, then perhaps disconnect the MPPT from the charger too to avoid draining the battery.
Super! The app records the reverse energy as well - that explains it all.
Thank you very much for sharing your knowledge!
