phelix avatar image
phelix asked
Driver issue reading RS485 Modbus RTU with Node-RED
Hello together,
I am trying to connect a rs485 Modbus RTU Generator to Node-RED large image 2.82 via the FTDI-USB-Serial cable. I have the node-red-contrib-modbus palette installed and downgraded node.js to version 12.22.12. and use the Modbus-Flex-Getter and debug node.
Sometimes values are transmitted, but most of the time errors or empty string is given back.
The debugging node in Node-RED prints following:
When debugging via SSH (DEBUG=contribModbus*,modbus-serial node-red -v) the following messages are received:
I have followed the howto https://github.com/victronenergy/venus/wiki/howto-add-a-driver-to-Venus
The ID was set to FT232_USB_UART_modbus in ft_prog, then added to the file etc/udev/rules.d/serial-starter.rules with "modbus" as VE_SERVICE.
serial-starter seems still to change drivers and baudrate each few seconds when grepping for the port:
1664973056948.pngIs there a easy option to set a fixed baud rate for a device (FT232R_USB_UART_modbus:9600) without interrupting the communication to the Carlo Gavazzi energy meter or writing a new dbus Driver ?
Or is there a better solution to read Modbus RTU values in Node-RED with the Cerbo GX?
kind regards and thanks in advance :)
cerbo gxNode-REDrs485driver
wjf avatar image
wjf answered ·
@phelix Did you ever get this sorted? Running Modbus RTU with the Victron?
phelix avatar image phelix commented ·
No, it hasn´t been resolved yet.
