philipr avatar image
philipr asked
No Output nodes available on multiplus
Hi! Just started a new Node red system on a Cerbo with a Multiplus -II 3000.
I've used both Node red and Multiplus-II before but with this installation its fighting back.
I can read input nodes from the multiples just fine, but when I try to use an output node on it, there's is none. The Solar charge output node works just fine.
What am I missing? The firmware is 481 (Newest is 489)
Multiplus-IIcerbo gxNode-RED
philipr answered ·
Updating to 489 wasn't the solution.
Mark avatar image Mark ♦♦ commented ·
That is quite odd, are you using a recent version of Venus large image?
Have you tried rebooting the Cerbo to begin with?
Can you turn the MultiPlus on/off and adjust the AC input current limit from the Venus menu?
philipr avatar image philipr Mark ♦♦ commented ·
Yes, newest version of the large image
Different types of reboots is done. The only thing I need to try is a complete reboot without the DMC panel attached and a reboot without the byd bms attached
Mark avatar image Mark ♦♦ philipr commented ·
Ahh, the DMC would disable on/off and AC current control from the Venus user interface, I think that is likely the issue. Unplug the DMC and either reboot or do a VE.Bus system redetect - then check again via Node-RED.
philipr answered ·
Turned out to be the DMC panel is blocking all communications from Node Red to the Multiples...
