bipedalprimate avatar image
bipedalprimate asked
Australia Grid Code N-bypass
What does N-bypass in the grid code selection for Australia mean?
Under what circumstances would you choose between the two options? ('no N-bypass' & 'with N-bypass')
Thanks,
Peter.
Multiplus-IIVEConfigure 3
5 comments
Rob Duthie avatar image Rob Duthie commented ·
Hi
Neutral
bipedalprimate avatar image bipedalprimate Rob Duthie commented ·
Thanks Rob.
Any thoughts on the second question about when you would use one or the other?
Rob Duthie avatar image Rob Duthie bipedalprimate commented ·
Hi
OK to do with the ground neutral bond test that the Multiplus does to check and see that there is neutral path.
Depends on your wiring of the inverter to the house loads etc.
Regards
Rob D
NZ
Rob,
So in a situation where a Victron Inverter AC-In is connected down stream of the main switchboard and its AC-Out supplies ALL house loads, should 'No N-bypass' be selected?
Correct.
raymiller avatar image
raymiller answered ·
Then what is the difference between options A, B&C?
Answering my own question above as to what A, B and C.
Setpoints are now defined by region of installation, as per the following categories:
  • Australia A: For large interconnected power systems, e.g. all Australian networks other than those specified below
  • Australia B: For small interconnected power systems, e.g. Western Power
  • Australia C: For isolated or remote power systems e.g. Horizon Power and TasNetworks
  • New Zealand: All systems in New Zealand
