Blue Smart IP22
Blue Smart IP22
Probably yes with the correct settings. I would consult the documentation for the batteries and see if you can set the system to do whatever that recomends.
What type of battery?
Many Thanks
Probably better to charge them at least monthly to avoid deterioration from sulphation.
Storage mode is a very good option if the charger has it.
Disconnecting for extended periods is not good.
37 People are following this question.
