Dylan Tucker avatar image
Dylan Tucker asked
Charging vehicle battery from DC to DC charger with MMPT Smart Solar
Hi all - I have a Citroen Relay that I've started the conversion process on. One thing I'm noticing is how quickly these van batteries drain when not in use due to the immiboliser and other gadgetry. I was hoping to come up with a way to have the vehicle battery at least trickly charged so this problem was mitigated. I so far have 2 leisure agm's and have started to piece together the components for a system, with 2 solar panels, an MMPT charger and a multiplus (all victron). I was considering a DC-DC charger too, but have started reading that it can be hard to get that working with an MMPT charger but have little other info on that side of things. Is that true and are there solid workarounds? I'm less worried about needing more power for the leisure batteries as if anything have probably overshot, but I really do want some sort of way to keep the starter battery topped up while sitting on the drive.
Thanks so much
battery chargingstarter batteryleisure batteries
Sarah avatar image
Sarah answered ·
You might want to consider a Cyrix battery combiner. Relatively cheap and simple to operate.
https://www.victronenergy.com.au/upload/documents/Datasheet-Cyrix-ct-120A-230A-EN.pdf
VictronConnect VE.Bus charging manual
